Hi folks,
I have installed OSMC on my RPi and today when I turned on my TV I saw it says:
Error installing:
Please report this on the OSMC forum.
So here it is.
Hi folks,
Error installing:
So here it is.
how about adding that link to that error message sam
so you and the mods dont have to repeat yourself
I’m getting a similar issues the past few days, glad it’s not just me, this is the error I get in the log
08:52:50.302 T:1184740336 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class 'socket.error'>
Error Contents: (2, 'No such file or directory')
File "/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/call_parent.py", line 18, in <module> sock.connect(address)
File "/usr/lib/python2.7/socket.py", line 224, in meth
return getattr(self._sock,name)(*args)
error: (2, 'No such file or directory')
-->End of Python script error report<--
Please provide complete logs especially apt logs
So I did turn the debug logging on and restarted the RPi. First off, it makes the system really slow; and then when I went through the shortest path to replicate the issue it didn’t showed this error! If I turn off the debug logging it will show it again though.I can tell that it happens every time I try to manually update the OSMC. I didn’t have time to go through the log file either. Probably will take me a couple of days to it but I will check it out and submit if I can find anything useful.
Cheers,
Here’s the link to my file:
Why not using OSMC log uploader or paste-log? Not feeling to good opening Dropbox links.
Also remember apt log would be crucial additionally to the Kodi Debug logs
Actually, never mind! I found the problem. I had added a repository to download a package but apparently the link to that repository was broken. Removing it from /etc/apt/sources.list.d did the magic. Thanks everyone for your prompt responses.
