I have the following issue: every OSMC related install fails, whether it is an update or when I’m trying to install e.g. Samba from the ‘shop’
No idea what’s going on here. What logs are relevant, so I can upload them?
(my Pi3 is connected to the internet)
UPDATE: running sudo apt-get dist-upgrade DID update my OSMC to the October 2017 version, whereas update via My OSMC fails everytime
Regards
Joost
Do I really need to dump all the log files?
No one else is reporting this problem. If you want it resolved we do need to see logs.
If you’re familiar with the command line then you may have made other modifications to your system which have caused this problem.
I hope you can understand. It’s like saying your car won’t start but refusing to lift your bonnet.
I don’t mind delivering the log files. I’m just wondering if all the files are necessary. In your words, do I need to pop the trunk for an engine problem?
Regards
Joost
If we give you the same answer a third time will it be sufficient?
The issue you are currently experiencing with OSMC
Updates for OSMC are failing to install
What you were doing when this issue occurred
Opened My OSMC > Updates > Manual > Scan for updates now
Whether you can replicate this issue on demand. If you can, then please provide some steps on how an OSMC developer can reproduce the same issue.
See steps above
The device you are currently running OSMC on
Raspberry PI 3
What peripherals are attached to the device?
External HDD, Wifi USB dongle, Keyboard USB Unifying receiver
Has this issue been introduced by a new version of OSMC? When did the issue first appear and can you recall a time when it was not present?
Nope, this issue has always been around
http://paste.osmc.tv/ededafotoj
Failed to fetch http://packages.unusedbytes.ca/dists/wheezy/main/binary-armhf/Packages
You need to remove all the cruft from your APT source file(s).
OSMC is currently on Debian jessie and soon to move to stretch.
How do I do that? This is new to me
====================== APT sources.list =================== ZZz2wrJ1
deb http://ftp.debian.org/debian jessie main contrib non-free
deb http://ftp.debian.org/debian/ jessie-updates main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb http://apt.osmc.tv jessie main
deb http://packages.unusedbytes.ca wheezy main
---------------------- APT sources.list END ---------------
It appears your /etc/apt/sources.list contains extraneous sources that are causing a problem… Remove or comment out the offending repo. We can only assume you added it as OSMC did not.
The same way you added it.
SOLVED
I removed an entry from
and now I get no error message when updating
Thanks guys!
