I own a Vero 4k+ which is connected to a Yamaha AV Receiver. In the settings of the Vero 4K+ is “Passthrough” for Dolby True HD activated. When I switch to a Dolby True HD track, I don’t get any sound. The display of the receiver switches to PCM. AC3 is fine though.
Any ideas on how to fix this? I really don’t want to buy a new receiver. It is a Yamaha RX V-2067.
reproduce the issue
I did a receiver reset and a clean install of the Vero 4k+ from an USB stick.
I used a downloaded sample for a TrueHD file. It’s also the same with my own saved BRs.
No. The Vero is connected directly to the AV Receiver. I also changed the AV (IN)port for the Vero. That changed nothing. The TV (an old Panasonic) is connected via the HDMI-(Out)port on the back of the receiver.
Ok, can you frist try whether you can set the output device at settings -> system -> audio -> output device to 'AML-MESONAUDIO, HDMI` ?
Although most possible not related to your issue: Why you have set Adjust Display Refresh Rate set to off instead of start/stop? (settings->system->player->video)
Also, you’re using a small GUI resolution; recommendation is to use 1920x1080 at system->settings->display.
Another cable and another port changed nothing. I also noted the following:
When I try to playback the TrueHD files I get no audio. When I change to DTS (even MA) /AC3 I get also nothing. I have to turn of the receiver to get the AC3/dts track again.
I think it’s time to get a new receiver (perfect time to buy one ). That think is almost 10 years old.
It’s just possible the tweaks which come to 19.3 may solve the problem, but I can’t guarantee OSMC will release 19.3 before Black Friday. Don’t hold back on a new receiver
