Thanks for confirming, would you mind letting me know which chipset are supported please?
Or a recommendation for a compatible decent external wi-fi adapter (with an antenna) so I get better signal strength and hence performance.
Currently, RTL8812AU is the only out of tree module we are supporting.
The internal adapter should be good enough for 4K; provided that you are using 5Ghz and not 2.4Ghz.
The internal adapter is connected via 5GHz to my router however the device is barely in range so the ‘connected’ speed drops right down / is abit flakey. It worked great when the device was nearer to the router!
So I figure I get a USB device with an external antenna.
So the the wireless adapter below (with this chipset - RTL8812AU)
Is recognised.
However…
Whenever I try connect to a network the UI (mistakenly connects using the on-board adapter (wlan1) when I’ve selected wlan0.
I’ve tried to disable the onboard adapter via command line but with no luck.
@sam_nazarko - I think there is some issue with the OSMC addon connecting to an external adapter, perhaps it wasn’t designed to do this? Maybe worth checking out if you have time and then adding to the backlog?
