I want to test OSMC but I don’t have a spare SD card.
So I tried to install OSMC through adding a custom OS on Berryboot. I ran into an error message, something like “fstab not installed”. I think this happens if the OS is not Debian based (enough).
Is it possible to install OSMC as a virtual machine in VirtualBox? I tried unsuccessfully.
Emulating VideoCore and Pi specifically under VirtualBox won’t work well. We will have x64 images within the month and these should work on VirtualBox (but obviously VirtualBox isn’t a target of ours so you will have to wait). We are working on getting NOOBS support for OSMC. This may be the best way to keep multiple Pi distributions on the same SD card.
