As title said: Osmc works fine: only h265 dvb channels don’t play. All channels play fine, low cpu work (25-35%) All h265 encoded channels return no data. Is h265 not supported?
What device is this on?
Regards Tom.
Raspberry pi4b
I have tried it with another distribution and works (h265, but all on software rendering so I remove it in place of osmc)
H265 is supported on Pi 4
Are you sure it is a Pi 4?
Sure.
Then I suggest to post a log so we can see what is going on.
reproduce the issue
upload the log set (all configs and logs!) either using the
