I’ve used the osmcinstaller with debian 8 just fine in the past, but now I’m using debian testin (with the gcc 5 and that stuff) and the osmc installer does not work. It runs gksudo, and the window is just blank.
Here is what it says running from a terminal:
$ osmcinstaller
/usr/bin/gksudo
X Error: BadAccess (attempt to access private resource denied) 10
Extension: 130 (MIT-SHM)
Minor opcode: 1 (X_ShmAttach)
Resource id: 0xd4
X Error: BadShmSeg (invalid shared segment parameter) 128
Minor opcode: 5 (X_ShmCreatePixmap)
Resource id: 0xd4
X Error: BadDrawable (invalid Pixmap or Window parameter) 9
Major opcode: 62 (X_CopyArea)
Resource id: 0x2200011
I can attach a strace or anything else if you need. Don’t know if it may be related to the fact that the new gcc is in testing now with the new ABI and that stuff.
I’m using osmc-installer package version 119 from http://download.opensuse.org/repositories/home:/osmc/Debian_8.0/
The version I had previously installed was 111, and it doesn’t work on debian testing either.
Please let me know if I can help and test anything. I really want to install osmc =)
