For best results, update via My OSMC.
Suggest to open a new thread and provide debug logs.
and now ? can i run into problems ?
Hard to say without proper logs, but it doesnât look like a significant issue, just locales not being generated properly.
mmmmm ok⊠i wait to 100%. reboot my pi2 and see the final result
Oh thanks for providing this ânewâ version
And again nö chance to install Netflix or Amazon Prime
On vero, if i remember itâs works, no works on other device like Raspberry.
Remember also⊠under the hood there is always and in any case Kodi with all its pros and cons⊠one for all itâs very difficult you can obtain an official addons for netflix and amazon prime.
EDIT
when I talk about official addons I mean that they are directly developed by Netflix or PrimeâŠand not that come out of the kodi.tv forum developed by some good willing userâŠ
I wasnât after this on Rpi4 was saying I moved my home automation to a dedicated Rpi4 leaving the vero4k for Kodi and media work anyway. I left behind all the install and dependencies on the Vero 4k of the home automation but would like to blow that away now
I had some hickups with the update on the RPi2 but nothing serious it seems.
After the update, OSMC booted with an update failed message but the version was correctly shown as 2020.10-1. The log showed some errors with the osmc settings:
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<â
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type âexceptions.TypeErrorâ>
Error Contents: canât multiply sequence by non-int of type âfloatâ
File â/usr/share/kodi/addons/script.module.osmcsetting.updates/service.pyâ, line 38, in
m = update_service.Main()
File â/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/update_service.pyâ, line 244, in init
self._daemon()
File â/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/update_service.pyâ, line 284, in _daemon
self.position_icon()
File â/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/update_service.pyâ, line 531, in position_icon
screen_width = screen_height * 1.7777777777
TypeError: canât multiply sequence by non-int of type âfloatâ
â>End of Python script error report<â
Also the manual update did not run again at this point:
WARNING: CPythonInvoker(10): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
Error Type: <class âsocket.errorâ>
Error Contents: [Errno 2] No such file or directory
File â/usr/share/kodi/addons/script.module.osmcsetting.updates/resources/lib/call_parent.pyâ, line 18, in
sock.connect(address)
File â/usr/lib/python2.7/socket.pyâ, line 228, in meth
return getattr(self._sock,name)(*args)
error: [Errno 2] No such file or directory
I rebooted once and no new errors were shown. Did the manual update again and it indeed did some additional updates. No differences in version shown at system info nor myOSMC. All seems good so far now.
Thanks for the report. Weâll look in to this issue.
Hey, thank you for the update. One thing Iâve been seeing with the last few updates is that after starting the update process, my TV turns off, probably because it gets told to do that via CEC.
This isnât great as I canât follow what the box is doing until I manually switch it on again.
With this latest update, has there been any change with respect to Wireguard?
I would potentially like to install a wireguard client to be able to connect to my PiHole VPN if im travelling with a Pi.
From what I read on the forums it had been possible to install wireguard but I think it would be likely beyond my technical abilities.
If there is now greater support for Wireguard i might give this a go.
(Basically its for if I want to tether the pi over USB to some wifi, it allocates a new IP every time which makes it difficult to connect to without a mouse or some other control method. I was thinking a link to my VPN might help with ZeroConf, that way I dont need to check the IP in Kodi each time?
When I set a static IP it always seems to loose internet)
Hi there. Thanks for the update! I installed it on my RPi3b. After the first reboot, I got the âSad Faceâ, but it went away on its own. I then restarted with only one issue: When Plex starts, there is no left-side menu for Plex any more, and I donât know how to configure it so that the left-side menu returns.
i keep getting this, not sure why youâre trying to write to /media as thatâs the autofs directory for mounts like usb or nfsâŠ
Preparing to unpack .../armv7-diskmount-osmc_1.5.7_armhf.deb ...
Unpacking armv7-diskmount-osmc (1.5.7) over (1.5.6) ...
dpkg: error processing archive /var/cache/apt/archives/armv7-diskmount-osmc_1.5.
7_armhf.deb (--unpack):
unable to create '/media/README.dpkg-new' (while processing './media/README'):
Permission denied
i managed to to the upgrade eventually using apt-get -f install but this package is getting stuck all the time now on all three vero4k+'s.
edit: systemctl stop autofs && apt dist-upgrade && reboot did it, bit naff though.
Hi Sam, I ran update on my Vero 4K+ and everything seemed to go OK, but I noticed in System Info that my kernel is 3.14.29-160-osmc. This does not sound right to me. I also ran update on RP3 and kernel is now 4.19.122-2-osmc. Both are Build: OSMC running Kodi 18.8 and Compiled: 2020-10-17. Any thoughts?
Glen
Wireguard as a kernel module is available in Linux 4.9 for Vero 4K/4K+
It will be available on Pi soon too.
But you will need to install and configure this yourself.
Iâd be surprised if this was CEC related. Itâs possible your device is switching to a resolution unsupported by your TV. A new thread could be opened to help us diagnose the issue.
The changes to Kodi are minor (18.7 â 18.8). Iâd suggest starting a new post outlining your issue in more detail.
autofs isnât something that we include by default, but we do support it. It might be worth checking your configuration is correct.
These are the correct versions. It looks like both of your systems have updated successfully.
Ok, so kernel is still 3.14⊠on Vero 4K? I wasnât sure because I have my other Vero 4K configured to get kernel 4.9 [Testing] build.
Thx
Glen
Yes â still 3.14 for now as there are still some issues to resolve with 4.9
This is expected behavior, at least with a RPi (no clue w/Vero), If you have the CEC options set to allow TV power control. I think if you manually reboot via Kodi the TV stays on but if you issue ârebootâ via CLI the TV turns off and then comes back on when Kodi loads again. This is not new behavior as iâd noticed this before the June 2020 update when I first enabled those options as part of OSMC remote keymap testing.
I noticed problem with ALSA and Pulseaudio. After upgrade I lost Pulseaudio from âaudio outputâ in KODI. Also ALSA sink in Pulseaudio is only mono (without other profile available). Aplay -l shows Pulseaudio, and its accessible from console, but not seen in KODI. I think about fresh install, but no image available.
Can anyone confirm?
