I’m using an HD Homerun to view OTA TV stations. I don’t know exactly when it started, but we can’t watch more than a few minutes of TV before it appears to freeze only to start up again 10 seconds later.
Tvheadend is used for PVR duties. Recordings don’t seem to have this freezing issue, however when pausing live tv, it will fail if I fast forward to live tv. What happens in this case is it will go back to the beginning of the live tv recording but I can only go forward a few minutes before it returns to the beginning again. I cannot get out of it by pressing the stop button. I’m forced to change to another channel and then change back to the original channel (losing whatever was in the paused buffer).
Now, I can watch the same hdhomerun using the app built into the tv and it works flawlessly (though I don’t have recording or pausing ability). This makes me think the problem lies in tvheadend, Kodi or the vero4k.
These are all good points. All the storage is indeed on a NAS. Up to semi recently, it was never an issue, that’s why I’m wondering what is going on.
Are there software tools you can suggest to measure network speeds between the Vero4K and the NAS? The Hdhomerun and the Vero4K are plugged into the same router, but the NAS is connected via powerline networking.
If your NAS allows for running iperf then this would probably be the prefered method…
The powerline adapter would be a likely bottleneck and I would actually suggest to reboot it first and see if the issue clears up since it would seem your saying this setup had been working previously. If feasible it would probably be best to move your NAS to a location where it can be directly connected to the router as well.
I am having very similar problems to the OP.
There is something going on with TVHeadend at the moment and it’s been like it for a few weeks.
The CPU load on my server slowly builds over 4 or 5 days and the TVHeadend stream becomes more unstable:
This is the version number:
HTS Tvheadend 4.2.8-36~g5bdcfd8ac
Looks to be from November last year and I’m pretty sure it hasn’t updated recently.
I wonder if it is a dependency or something that TVH relies on to run that’s updated and causing an issue?
I run TVH on a headless linux server
