Just installed the update and I actually really like the idea! Nice work! I’m having trouble with Rotten Tomatoes, can’t make it show, … but I guess it is something with Universal Movie Scraper. Also, is there a way to show Metacritic in format XX, not X.X
edit: oh, and one more thing, I’m not a fan of auto scrolling large blocks of text with extended movies plots on second screen, can we scroll trough it manually in some way? I know it would require some new UI elements, but maybe it is already doable and I dont know how
Not sure about Rottentomatos, but I think you need an API key which they only hand out to Patreon backers at the moment.
Thats unfortunately the only way to show it, if the scraper doesn’t offer any options. The skin is simply showing what the scraper puts into the database field for ratings.
That was the way I planned to do it initially for the second screen plot text, but the manual scrolling (scrollbar) is utterly broken in Kodi for textboxes in Kodi, it seems.
I would like to install latest changes made for official osmc skin, but I would also like to remain in stable osmc update channel. Is it contradictory? If not how to install latest osmc skin update?
We believe this is a Kodi issue or a specific Kodi function and as such you should look at addressing the issue there. If you do believe that this is an OSMC specific issue, please let us know.
