I frequently use my OSMC setup (Pi2) to listen to music. The last couple of days OSMC freezes after a few songs on party mode. The problem seems to be with Kodi itself, as restarting mediacenter restores things.
I grabbed debug logs, but was unable to upload them (probably because filesize is too big… kodi.old.log is 90MB. This was from a fresh reboot to lockup, so this is all new messages from the lockout!)
osmc@osmc:~$ grab-logs -A
Exception Details:
File "/usr/bin/grab-logs", line 636, in dispatch_logs
raise ValueError('Upload Returned Empty String')
ValueError: Upload Returned Empty String
Failed to upload log files, copying to /boot instead. (Unable to verify)
thanks @sam_nazarko I’d be happy to test an alternative that you think might help.
I left OSMC running overnight on PartyMode, trying to trigger lock up again. It was not frozen when I checked in the morning, but the music had stopped and it seemed to have rebooted itself. I want to bed just before midnight, and the first song playing was something by Toni Braxton. I can see this in kodi.old.log, which is why I think the system had its own reboot (possibly due to internal error?)
I noticed the last line in the log (and in my previous log) has to do with Music Visualization. I thought Music Visualization no longer works, so is it causing some issue, or is that just a coincidence?
That line is nothing to do with your problem. That is the MyOSMC settings addon sending a periodic “ping” to the log file which includes the name of the currently displayed Kodi screen - in your case MusicVisualisation.xml.
If you check your log for “blurp” you’ll see these logged periodically.
