I updated OSMC on my Raspberry Pi. As usual after the updates I mount my network Western Digital Drive. I usually use “password”. But it is giving me a message “unable to find suitable address”. I pinged the IP of the drive and it was pined successfully. Any suggestions on what could be wrong or how to fix ?
I restarted the router and the network HDD. Mounted the public drive from windows explorer. THe private drive reconnected by itself. Ran the mount commands from putty and they mounted this time.
I have not had this issue before. So am not sure what caused this.
However thank you for your response to my request for help. Appreciate it.
