So I just installed this version of osmc: OSMC_TGT_rbp1_20190105.img (and plugged the sd card straight in), on my rp0 and any peripherals I plug in don’t work (wireless keyboard, gamepad, usb keyboard, usb mouse). I am stuck on the setup screen and nothing seems to have worked. I have been searching for days in the forum but nothing has worked.
I have had this issue when I previously installed osmc and gave up on it. Any ideas on what I could do? Or what info I can provide you to help me?
I would suspect power. What kind of power supply are you using? A phone charger or an official power supply?
a xiaomi power brick and cable it’s 5V/2A. I didn’t have this problem with other operating systems though.
I tried a 5.1V/2.4A source but it still doesn’t work.
A quick google search reports results of fast charger, which means it will not constantly be providing 2A. Best bet is an official pi psu.
Is this another charger? Please provide more details make and model?
Thanks Tom.
it’s the xiaomi powerbank 2c
Which again is used for charging devices. You will have more success with an official power supply.
Tom.
I’ll order one up and tell you what happens
simple way to know if there is an issue, the way to do this is
cat /sys/devices/platform/soc/soc:firmware/get_throttled
if it replies with anything else then 0 there could be potential issues with the charger also dmesg will show entry logs from the kernel if under runs are detected.
where do I enter this command?
via ssh use the link tim supplied. there is a good reason why any old charger isnt viable for rpi sadly this is lost for users since all they see is the micro usb slot
I am stuck in the setup screen, so I can’t setup an internet connection to connect via ssh
The Power Supply just arrived, it still isn’t working.
reboot the OSMC device
reproduce the issue
upload the log set either using the
As I said nothing is responding I can’t enter any menu or do anything
Could you please provide a photo of this?
How are you preparing the sd card? Are you using the OSMC installer?
Thanks Tom.
I tried flashing the img both with etcher and win32diskimager
I am going to provide you with an image in 1 minute
