https://paste.osmc.tv/avejeneyam
I was encountering problems running Netflix and decided to reinstall it. That has not solved anything but it seems to be worse now. Please help in getting to the bottom of this.
ooZee
19 June 2020 12:18
2
It would me much better if you’d describe your problems and attach a debug-enabled logs.
Netflix changed some things, and that broke the Netflix addon. I reported it to the authors here:
opened 05:11PM - 17 Jun 20 UTC
closed 06:39PM - 24 Jun 20 UTC
Triage: Confirmed
Resolution: Fixed
## Bug report
#### Your Environment
- Netflix add-on version: 1.4.1
- Opera… ting system version/name: MacOSX
- Device model:
Used Operating system:
* [ ] Android
* [ ] iOS
* [ ] Linux
* [x] OSX
* [ ] Raspberry-Pi
* [ ] Windows
### Describe the bug
Login fails with KeyError.
https://paste.kodi.tv/awisikaboh.kodi
#### Expected behavior
Expect to be able to login.
#### Actual behavior
I get an error dialog box.
#### Steps to reproduce the behavior
1. Install addon
2. Run addon
3. Try and login
#### Possible fix
### Debug log
<!--- How to:
1) Go to add-on settings, in Expert page and change "Debug logging level" to "Verbose"
2) Enable Kodi debug: go to Kodi Settings > System Settings > Logging, and enable "Enable debug logging"
3) How to get the log file? Read Kodi wiki: https://kodi.wiki/view/Log_file/Easy
RESPECT THE RULES!
- A DEBUG LOG IS ALWAYS MANDATORY WHEN CREATING AN ISSUE. PROVIDE A LINK TO THE LOG!
- DO NOT PASTE THE CONTENT OF THE LOG HERE
- DO NOT CUT THE LOG
- If the log file is really huge (more 1Mb) in Kodi settings disable "Component-specific logging" then create a new log
The debug log can be found from this link:
### Additional context or screenshots (if appropriate)
#### Installation
* [ ] I'm using other Netflix Repo
* [ ] I'm using a different source
#### Other information
#### Screenshots
This addon respects the same rules used in the Kodi forum
https://kodi.wiki/view/Official:Forum_rules
therefore the single violation will eliminate your request
In that thread there is a hotfix zip you can download to fix the issue for now.
