PGS subtitles appearing dark grey in HDR
No, I tested with Kodi v21.3 on Windows. As long as HDR is enabled in the Windows Display Settings, Kodi in HDR mode shows HDR subs correctly, exactly like a UHD Blu-ray player.
Thanks for confirming. That’s weird as the patches in CPM/avdvplus/pannal builds aren’t in the standard Kodi 21.3 afaik.
I guess Kodi on Windows uses some Windows functionality for this as HDR PGS is only correct on Windows.
I haven’t downloaded May OSMC yet, via FEL the Godfather subs are ok with OSMC but better with avdvplus CE.
and it was 4 years ago I posted that clip? Where did the time go :thinking:
So three more months and I think we have a solution. It will need to be built and put into staging - just waiting for @sam_nazarko to find time for that.
