Hi all!
Over the past years, I have been happily using my setup combining
- LG OLED C9 television
- Philips Hue HDMI Sync Box
- Philips Hue Gradient Light Strip
- Vero 4K+
While I previously primarily played BluRay sources, I have also started to watch more Web-DL sources. When I watch BluRay sources (1080p and 4K, including HDR in some cases), the light strip works perfectly. No latency whatsoever. However, when I play Web-DL sources, there is a noticeable latency (roughly 1 or 2 seconds) between what’s shown on the television and the colors of the light strip. It also feels a bit “choppier” in the way the colors are “moving around”.
Any idea what the cause could be? And if this potentially will be gone when I start using my Vero V (which is soon to be delivered
Many thanks in advance for your responses!
