ok so here is the deal i have a Pi0W with no usb support im trying to install osmc on it i have an image from my other pi0W and i can find the settings in the connman folder but they seem to be tied to the mac address and without being able to access the pi through usb for ssh or basic install i was looking for something i could write to the sd that would pull the MAC from the pi without connecting or even if i unsecure my network it would auto connect so i could get it from the router or a config file generated on the sd… thanks for any help in advance
So you don’t have a TV and Remote Control on hand to do the install?
i have a tv but it doesn’t matter the the usb port on the pi is faulty so i have no way to connect to it i can only write to the sd card untill i can get it connected to the network then i can access it remotely
Control via CEC ![]()
do you have a good tut on hand for this… it would be nice lol been working on this for prolly 8 hours if not i have no problem with google ![]()
Well if your TV supports CEC (any TV should do nowadays). You just plug the HDMI cable into the Pi0 and then you boot it up and controll it via your TV remote. You can than join it to your Wifi via MyOSMC.
awsome!!! had to change some settings by moving sd to the other pi not sure what actually made it work between tv settings or the pi settings but either way fixed thank you verry much lol wish i had asked about this 8 hours ago… i have been scanning through system files in the pi and every thing lol but all good now thanks again
