I have a Pi 2 with an Edimax usb dongle. I want to connect to the wifi network being broadcast by my Android phone. The Pi sees the network but won’t connect. However it will connect to my sons iPhone wifi.
Can someone please tell me where the OSMC wifi configuration file is located and I’ll try to set it up manually.
I solved the problem myself. Raspbian and OpenElec both identify the wifi dongle and connect to the Android phone network
