Pi 3 won't boot
I already posted logs: https://paste.osmc.tv/nakajupujo
The network I was trying to connect to was the same one I was trying to pre-seed.
I tried moving my 2.4GHz network from channel 13 to channel 11, and it now shows up in the list of WiFi networks, so that’s clearly why it wasn’t appearing before - the Pi just can’t see channel 13. But when I try to connect to it, I get the same error that I got for the 5GHz network, and it doesn’t connect.
From the log, it doesn’t look like you’ve installed (and configured) the crda package
  1. How do I do that?
  2. Is that something that should be installed as standard?
  1. sudo apt-get install crda. Set REGDOMAIN in /etc/default/crda.
  2. Direct that one to Sam.
Okay, I set REGDOMAIN to GB, and now the 2.4GHz WiFi network on channel 13 is visible - which is cool! On the face of it, that does seem like something that ought to be installed by default…
This hasn’t fixed the error I’m getting trying to actually connect to a WiFi network, though.
Should I reinstall OSMC without pre-seeding a WiFi network and see if that helps? Or do you need fresh logs, or…?
I was hoping that Sam would have provided input regarding the preseeding process. I know very little about how it works.
Have you tried via connmanctl to see if it just a MyOSMC issue?
I haven’t. You’re going to have to talk me through it or point me to a tutorial, though. :slightly_smiling_face:
I don’t think I’m doing this right. Error messages everywhere. :slightly_frowning_face:
osmc@osmc:~$ connmanctl
Error getting VPN connections: Rejected send message, 2 matched rules; type="method_call", sender=":1.29" (uid=1000 pid=1006 comm="connmanctl ") interface="net.connman.vpn.Manager" member="GetConnections" error name="(unset)" requested_reply="0" destination="net.connman.vpn"
connmanctl> scan wifi
Error /net/connman/technology/wifi: No carrier
connmanctl> services
*AO Wired                ethernet_b827eb2723d9_cable
connmanctl> agent on
Agent registered
connmanctl>
Is Wifi disabled in MyOSMC?
What does cat /proc/net/wireless give you?
Or iwconfig?
Oops, I had temporarily disabled it, yes. It went better this time, but the final stage still errored:
connmanctl> connect wifi_b827eb72768c_42616720456e64_managed_psk
Error /net/connman/service/wifi_b827eb72768c_42616720456e64_managed_psk: In progress
connmanctl>
And I’m not sure at what point I’m supposed to enter the password…?
osmc@osmc:~$ cat /proc/net/wireless
Inter-| sta-|   Quality        |   Discarded packets               | Missed | WE
 face | tus | link level noise |  nwid  crypt   frag  retry   misc | beacon | 22
osmc@osmc:~$ iwconfig
-bash: iwconfig: command not found
Did you remember agent on ?
You are the first person in the UK I’ve seen using channel 13.
Usually that’s a German thing, and even then, very rare.
Wouldn’t installing crda by default and setting REGDOMAIN to GB be a good idea for someone whose location is in GB? Maybe that would have some negative side effects, I don’t know…
Pretty sure I did, but I’ll try it again when I have a moment.
I got bored of grappling with the WiFi, and decided to reinstall OSMC, this time selecting ā€œwired networkā€ in the options when initialising the SD card. Having gone through the installation process again, I’m now able to connect to my 5GHz WiFi without any errors.
I am therefore confident that the root cause of the problem was the original attempt to pre-seed a WiFi network while initialising the card. Somehow that not only prevents it from connecting to the pre-seeded network, but it spoils things so badly that any attempt to connect to any WiFi network after that fails.
I’m going to let this thread lapse now, as it has already drifted away from its original topic (what turned out to be a dodgy memory card). I might re-raise one or two other things in threads of their own if the mood takes me!
