PI-DAC+ audio card after bluetooth a2d2p
Hello, I was one of the people testing the Bluetooth audio, I have now replaced it with a Pi-DAC+.I can hear clicking but it is not showing up on audio section.
i have enables sound card overlay
Please help
dtparam=audio=ondtoverlay=iqaudio-dacplus-overlay,unmute_amp
#dtparam=audio=off
#dtoverlay=iqaudio-dacplus
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
max_usb_current=1
dtoverlay=pi3-disable-bt
lcd_rotate=2
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
gpu_mem_256=112
sdtv_aspect=1
gpu_mem_512=144
hdmi_ignore_edid=0xa5000080
dtoverlay=spi-bcm2835-overlay
decode_WVC1=0x88fb2f2a
decode_MPG2=0xd3f57265
Have you configured the Overlay for the DAC?
Yes to Pi-DAC+
in services pulse services has stopped. could that be the reason?
Pulseaudio has been moved to be started differently. But Pulseaudio should not be influencing your PI-DAC. Maybe remove a2dp-osmc-app.
Also you dtoverlay config looks strange. Where did you get this? The two lines you have commented out should be the right ones.
After removing the a2dp-osmc-app, I can now select it in audio but no output from dac…
So how about the overlay?
Figured the cause, I have Raspberry Pi USV PiUSV+ UPS. WHEN that connected, i get not sound from DAC. With the ups removed, I get sound from dac.
the UPS has been stable until this issue
I want to use both but don’t know how get both stable…
Could it be a GPIO overlap?
I has to be, How do I correct it gpio overlap?
I believe the dac used pins between 1 to 11 but iI have no clue what GPIO the UPS uses
