Device: (Rasp Pi 2)
Installation media: (SDcard)
Connection: (Wifi)
Power Supply Type: 220V/2A
Power specs: ?
Peripherals: PAL Monitor / rapoo 3600 touchpad keyboard
Storage Device USB3 HDD 2TB
OSMC version: July 2015 2015.07-1
XBMC version: ?
Codecs: mpeg2
Audio/Video Output: (hdmi / analogue auto)
Overclocked: no
Config.txt Extras: no
LINK to uploaded logs in pastebin (atociwinuy)
my problem is as follows:
in OSMC / PiConfig / Hardware Support / Soundcard Overlay
I have choosen: iqaudio-dacplus-overlay
in OSMC / PiConfig / Config Editor:
dtoverlay=iqaudio-dacplus-overlay
in Einstellungen (Options?) / System / Audio-Ausgabe I have
PI : Analogue
if I change this to ALSA:Default (IQaudIODAC Analog)
the system freezes and I have to pull all cables to reanimate the Raspi.
I have read what I found concerning the Pi-DAC+ card to no avail.
Any help?
Thank you
Ben
I have also noted that the PI DAC+ causes playback issues with certain files. Playing just through the PI (analogue or HDMI) without the overlay the files play fine, enable the overlay and the video stutters but audio plays okay.
I pulled off the codec info for two that have this issue:
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 42mn 57s
Bit rate : 942 Kbps
Width : 640 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.140
Stream size : 290 MiB (83%)
Writing library : XviD 1.0.0 RC3 (Nihao) (UTC 2004-03-22)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 2000
Duration : 42mn 57s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Delay relative to video : 30ms
Stream size : 59.0 MiB (17%)
Alignment : Split accross interleaves
Interleave, duration : 192 ms (5.75 video frames)
Interleave, preload duration : 192 ms
and
Video
Format settings, BVOP : 1
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 1h 31mn
Bit rate : 867 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.118
Stream size : 570 MiB (81%)
Writing library : DivX 5.2.1 Beta (UTC 2004-09-08)
Audio
Format : AC-3
Format profile : Dolby Digital
Codec ID : 2000
Duration : 1h 31mn
Bit rate : 192 Kbps
Stream size : 126 MiB (18%)
Interleave, duration : 96 ms (2.30 video frames)
Interleave, preload duration : 96 ms
