OSMC is running fine!
Now i want to install Pi-hole on the same machine, it is a Pi3+
The installer stops and there is no feedback.
Dit some one tried this before and maybe could give me some advise?
THX!
This is the installer cli:
[✓] Disk space check
[✓] Update local cache of available packages
[✓] Checking apt-get for upgraded packages… up to date!
[i] Installer Dependency checks…
[✓] Checking for apt-utils
[✓] Checking for dialog
[✓] Checking for debconf
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[i] Using Google DNS servers
[i] Static IP already configured
[i] Unable to find IPv6 ULA/GUA address, IPv6 adblocking will not be enabled
[i] IPv4 address: 192.168.1.10/24
[i] IPv6 address:
[i] Web Interface On
[i] Web Server On
[i] Logging On.
[✓] Check for existing repository in /etc/.pihole
[✓] Update repo in /etc/.pihole
[✓] Check for existing repository in /var/www/html/admin
[✓] Update repo in /var/www/html/admin
[i] Main Dependency checks…
[✓] Checking for bc
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for dnsutils
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[✓] Checking for dns-root-data
[i] Checking for resolvconf (will be installed)
[✓] Checking for lighttpd
[✓] Checking for php-common
[i] Checking for php-cgi (will be installed)
[i] Checking for php-sqlite3 (will be installed)
and here is stops
