Hi, I’m using the Pi Zero, and I’m trying to setup the wifi. But I have a problem: I can olny use one device at the time. So, is there a way to connect to the wifi editing some config files? I can only use he keyboard and then plug in the wifi dongle after the reboot. Basically, I’m trying to achieve something like this: https://davidmaitland.me/2015/12/raspberry-pi-zero-headless-setup/
Hopefully someone can help me. By the way, I’ve tryied the headless guide above but it didn’t work.
