Hi. First, I’d like to thank You Sam and the rest of OSMC Team for Your outstanding job.
I have a problem with my OSMC instance - every couple of days it just hangs and it is impossible to log on to even via SSH. It happens without any wisible reasons - for example today in occured just after I run command sudo apt-get update via ssh. Only way to un-hang is to switch power off and on again. Today I had to reset it couple of times, because it hung on the OSMC initial screen while displaying starting services. My Raspberry is running newset version of OSMC with additional: Owncloud, Moonlight and Retrosmc. My AC adapter is the original one for raspberry pi 2.
I haven’t tried neither unplugging xbox controller nor enabling max_usb_current. I will do that now.
I’ve tried with a different power adaptor, but it’s not helping.
Hangs can be caused by many different things, that does not mean they have the same cause.
I see no logs from you, no detailed description of your problem in other forum posts in fact this appears to be your first post to the forum.
If you would like some help in troubleshooting a problem please start your own thread and provide debug logs and a description of your setup, what you are doing when it hangs and so on.
Hello again, Im digging up this thread, because after several weeks of flawless work, my Pi keeps hanging while browsing my music library. Only solution is to disconeect it’s power. Here are the logs: http://paste.osmc.io/lusumekagu
13:44:33 78.449448 T:1958470192 DEBUG: GetArtistsByWhere query: SELECT artistview.* FROM artistview WHERE (artistview.idArtist IN (SELECT song_artist.idArtist FROM song_artist) OR artistview.idArtist IN (SELECT album_artist.idArtist FROM album_artist)) and artistview.strArtist != '' and artistview.strArtist <> 'Różni wykonawcy'
Does ‘Różni wykonawcy’ mean anything? Not sure if that is corrupt or a foreign name being printed with the wrong encoding. Deleting the music database and rescanning might be the best option.
My Guess is that only Kodi hangs, so I would avoid unplugging power as it can lead to filesystem corruption and you will have worse issues from that.
Try to access OSMC via ssh and do sudo systemctl restart mediacenter instead
Yup, no luck with the keyboard on as well. I also think that this may be the end of my sdcard. Tomorrow I will get my samsung pro delivered, so I’ll install OSMC on it.
Hi, sorry it took so long to reply. After changing the sdcard to Samsung PRO and over a month of testing i can kindly report that everything runs even better than great, thank You for help and all Your work, guys.
