Hi guys,
I received my Pi3 yesterday and immediately went to work installing the latest version of OSMC on it (or rather the SD card that’s going into it). I love the features OSMC provides so I’ve been making the move to it from OpenELEC.
There are a couple problems, however. Videos play fine, it seems, but navigating menus causes the OS to hang for a while before loading the next screen or in some cases, freeze altogether. There was a point as well where I had to wipe the SD card and re-install following a constant “unable to build shortcut menu” error, but I suspect that’s related to the skin I had enabled at the time.
And on the note of skins, what happened? It’s just a cosmetic issue obviously and probably not too much of a concern, but a lot of the skins that were originally available under the “Get More…” option are missing, even ones I installed mere weeks ago on a different Pi. Am I doing something wrong or has support for some skins been dropped with this newest version of OSMC?
Sorry for my dumb issues, thanks guys!
