running an pi4 with a brand new hifiberry dac+dsp I’m stuck. No option to activate the dsp in the gui.
what i did:
- install osmc of june
- enabled spi in myOSMC
- rebooted
- following hifiberry-dsp/README.md at master · hifiberry/hifiberry-dsp · GitHub
- sudo apt update
- sudo apt upgrade
- sudo apt install build-essentials
- sudo apt install pip
- run bash <(curl https://raw.githubusercontent.com/hifiberry/hifiberry-dsp/master/install-dsptoolkit)
- reboot
- myOSMC: select hifiberry-dac
BUT not even an dsp option.
has anyone managed to set up an hifiberry dac+dsp on osmc??
thx…
