I make a fresh install of the newest OSMC its pretty fast on new sd card which i eject from my phone.
Now i start to configure hifiberry exactly like there
https://www.hifiberry.com/guides/configure-osmc-for-hifiberry/
None of that is really necessary. The 4 steps from my link above should be all that is required.
- Programs → OSMC Settings → Pi Config → Hardware Support → Soundcard Overlay
I chose “hifiberry-digi-overlay”.- Programs → OSMC Settings → Pi Config → Hardware Support
I disabled “Enable LIRC GPIO support”- reboot OSMC
- Settings → System → Audio Output → Audio output device
Here I chose "ALSA: Default (snd_rpi_hifiberry_digi S/PDIF).
Everything ok, but still the silence.
i again run dmesg
3.172511] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.175395] fuse init (API version 7.23)
[ 3.439528] systemd-udevd[127]: starting version 215
[ 3.440323] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 3.440347] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 3.702682] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f2 00000
[ 3.702928] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 3.702949] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 3.705114] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 3.705338] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 3.705357] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 3.708006] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 3.708035] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 3.719034] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not regist ered
[ 3.719064] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 3.796468] wm8804 1-003b: revision E
[ 3.802829] snd-hifiberry-digi sound: wm8804-spdif <-> 3f203000.i2s mapping o k
and aplay -l
osmc@osmc:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HifiBerry Digi HiFi wm8804-spdif-0
Subdevices: 0/1
Subdevice #0: subdevice #0
Anyone can help me ?
1 thing i did not see in the thread above
go to: system/settings/system/audio output/enable passthrough
hope it helps
I’ve been trying with passthrough ON and OFF and still the silence
SPDIF are lighting, all conections to external DAC is ok.
stupid question maybe. i gues you try to make optical working.
is it possible to switch to a coax cable and connect that to your amplifier to see if that is working.
ps had same probleems with digi+ ,i used the wrong input in my amplifier
hehe thanks for new idea… but it’s dosn’t work too still silence.
I have just the device you bought. It works over spdif for me. Video jitters in OSMC, bit not in OpenElec. Anyway, I’ll do a clean setup with the latest version one of these days and post the steps here, maybe it helps you…
