Using the latest OSMC on a Pi2 I thought I’d give the PiGlow a go.
Using the tutorial below I can get the lights to light up happy days
This tutorial explains how to get the lights working with RaspBMC sadly this doesn’t work with OSMC. http://falldeaf.com/2013/11/the-xbmc-piglow-information-display-addon/
Can anybody point me in the right direction or can OSMC support PiGlow directly?
I would like to know too I posted a similar topic. Maybe you can gain some insight from the link I provided. If you do I’d really appreciate some light on the matter. I can’t get the test.py example to run because of RPI.GPIO
I’d be very interested in making this work under OSMC
added a test script dunno if it works since i dont have a piglow but its worth testing out
