Thanks. I will test the image. In my case, with crda 5g WiFi is working but 2.4g don’t.
So……
I’ve testet the Image in different setups and get different results for connectivity. In short, please try the following procedure:
- connect the raspy only wired
- use the last image that you have provided
- make a fresh install
- finish the walkthrough (name, ssh, regional settings)
- do not(!) change the keyboard layout
then
- do not(!) enable wifi
- download the latest update from sam via update scheduler
- reboot
- connect via ssh and apply the crda fix, use capital letter for region code (in my case DE for germany
- reboot
- enable WiFi now, you should now be able to connect to 2.4ghz as well to 5ghz
- disable wired adapter
With this procedure actually now everything is working fine for me. Give it a try!
Hello
So I´m happy, that you have now all working, unfortunatelly for me after your setup still 5 Ghz wifi not working.
@fzinken advise sudo iw reg set CZ working (no error and correct result for get command), but not help in my case. Maybe the problem is CZ wifi zone. (but adjustment of DE also not help)
Here is logs from my previous setup
http://paste.osmc.tv/uposaqiyok
and here is log from last setup
http://paste.osmc.tv/enukuqoros
Problematic network SSID is “pf-JanS_5G”
in last case when I select disconnect 2.4 GHz network before connecting 5GHz I saw sad face.
You should set the zone permanently in /etc/default/crda. Then reboot.
AFAIK, all EU country codes should have the same effect, so CZ should be fine.
I think, that problem is different that wrong zone
Zone is setup correctly:
osmc@osmc:~$ sudo iw reg get global country CZ: DFS-ETSI (2400 - 2483 @ 40), (N/A, 20), (N/A) (5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW (5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW (5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS (57000 - 66000 @ 2160), (N/A, 40), (N/A) osmc@osmc:~$
Perhaps, but it’s still worth setting it properly.
Of course. I set it up and no change - 5GHz still no working
Which channel is that one on?
Also is your problem to see it or to connect to it. If just the connection is the problem I suggest to try from command line instead of via MyOSMC.
Hello
Usually I have adjusted “Auto”, but situation is same even if I set channel 36.
I have not problem to see the network - only if I try to connect to this network I see in top right corner
“Wireless
Connection to pf-JanS_5G failed”
In status I see “No wireless connection”
Last log right after this error is here: http://paste.osmc.tv/etidotuwur
Jan
Suggest to try connecting via Command Line instead of MyOSMC.
In Commandline start connmanctl and execute the following:
agent on scan wifi services connect SERVICENAME
Details regarding how to access the command line interface can be found here on our Wiki: Accessing the command line - General - OSMC
Hello
After some test I finally connect to 5 Ghz Wifi, but speed was very low.
osmc@osmc:~$ connmanctl
Error getting VPN connections: Rejected send message, 2 matched rules; type=“method_call”, sender=“:1.30” (uid=1000 pid=709 comm="connmanctl ") interface="net.connman.vpn.Manageconnmanctl> agent on
Agent registered
connmanctl> scan wifi
Scan completed for wifi
connmanctl> services
*AO Wired ethernet_dca6320eb736_cable
*A pf-JanS wifi_dca6320eb738_70662d4a616e53_managed_psk
pf-klivie wifi_dca6320eb738_70662d6b6c69766965_managed_psk
pf-JanS_5G wifi_dca6320eb738_70662d4a616e535f3547_managed_psk
Valtera wifi_dca6320eb738_56616c74657261_managed_psk
pf-klivie_5G wifi_dca6320eb738_70662d6b6c697669655f3547_managed_psk
Valtera_5G wifi_dca6320eb738_56616c746572615f3547_managed_psk
net-vychod wifi_dca6320eb738_6e65742d767963686f64_managed_none
Martina wifi_dca6320eb738_4d617274696e61_managed_psk
Vodafone Internet wifi_dca6320eb738_566f6461666f6e6520496e7465726e6574_managed_psk
DIRECT-CD-HP DeskJet 4530 series wifi_dca6320eb738_4449524543542d43442d4850204465736b4a6574203435333020736572696573_managed_psk
pf-mom, click here for internet wifi_dca6320eb738_70662d6d6f6d2c20636c69636b206865726520666f7220696e7465726e6574_managed_psk
marie@bok.net wifi_dca6320eb738_6d6172696540626f6b2e6e6574_managed_psk
netis_2.4G_32642A wifi_dca6320eb738_6e657469735f322e34475f333236343241_managed_psk
connmanctl> connect wifi_dca6320eb738_70662d4a616e53_managed_psk
Connected wifi_dca6320eb738_70662d4a616e53_managed_psk
connmanctl> disconnect
Error ‘disconnect’: Invalid argument
connmanctl> disconnect wifi_dca6320eb738_70662d4a616e53_managed_psk
Disconnected wifi_dca6320eb738_70662d4a616e53_managed_psk
connmanctl> connect wifi_dca6320eb738_70662d4a616e535f3547_managed_psk
Agent RequestInput wifi_dca6320eb738_70662d4a616e535f3547_managed_psk
Passphrase = [ Type=psk, Requirement=mandatory, Alternates=[ WPS ] ]
WPS = [ Type=wpspin, Requirement=alternate ]
Passphrase? xxxxxxxxx
Connected wifi_dca6320eb738_70662d4a616e535f3547_managed_psk
After restart when I try to connect I recieved this error:
Error getting VPN connections: Rejected send message, 2 matched rules; type=“method_call”, sender=“:1.33” (uid=1000 pid=811 comm="connmanctl ") interface="net.connman.vpn.Manageconnmanctl> agent on
Agent registered
*A pf-JanS_5G wifi_dca6320eb738_70662d4a616e535f3547_managed_psk
Agent ReportError wifi_dca6320eb738_70662d4a616e535f3547_managed_psk
connect-failed
Agent request cancelled by ConnMan
Error /net/connman/service/wifi_dca6320eb738_70662d4a616e535f3547_managed_psk: Operation aborted
connmanctl>
Logs: https://paste.osmc.tv/mifilahozi
O second attempt the pasword was not asked - I think it is already saved?
Jan
We have seen that before, the Pi4 Wifi has not the greatest performance.
Check with wavemon the wifi quality and with iperf3 the actual throughput.
