In Settings, Radio & TV, Playback:
item Play next programme automatically
The helpful tip underneath says:
Enable hardware video decode using Amlogic decoder
What does this tip have to do with playing the next programme automatically?
Was discussing the other day. Looks like upstream strings are out of sync.
I’ll sort this out shortly then update you, but this is a cosmetic issue so nothing to worry about.
