Hi there,
I am struggling with the last step of my “turn home cinema on” script I made with Home Assistant. Maybe one of you guys have an idea here.
I want to play a THX/Dolby Atmos theme (mp3) when the script is triggered. Here I dont know how to approach this.
ATM the Vero is always on, so sth. like “play sound when Vero/Kodi is turning on” would possible with some further effort
Playing a local MP3 via OSMC would turn on the local player, but I want to have the movie screen when projector is turned on
The only Add-On in this direction I know is CinemaVision, but I didnt found a fitting feature on a first view into it. Maybe there a others that could solve this…?
You might find some kind of a workable solution with the Kodi Callbacks add-on. I’m not sure what this would consist of but it is quite flexible in what it allows you to do.
After thinking about it playing a video teaser intro would also work out. Hitting all the right timings is not easy (e.g. the beamer needs x seconds to boot and the light transitions should fit) but I can do this afterwards.
In this case I would continue the script with a push of the home button via the harmony hub so I land again in the movie menu.
Edit: Formatting a bit broken but it works out in real.
Ha, I found a not perfect but working solution.
I installed the Rapier UI and put a Atmos Trailer via Splash Screen into the startup sequence. Put one of the smart plugs between power and the Vero, and in HA I only added an power off/power at the beginning of the script. Will tune some timings and then post a short impression how it looks.
Would still be developing addons for HA but its too unstable imho moved on to Openhab instead but my untappd addon is still available for HA along with my rpi power addon
