That was when you ran sudo apt-get install --reinstall vero3-mediacenter-osmc?
After you executed that type reboot in your ssh session.
Yes
rebooted and still doesn’t work
Ok, may try to check more details on the SMB issues hoping that gives us an idea.
Enable Debug logging and the component specific logging on “Verbose SMB Libary” and then upload logs after trying to play a video. We just need Kodi Logs so can use grab-logs -X and share the URL.
enable component-specific logging for all components
enable event logging and notification event logging
reproduce the issue
upload the log set (all configs and logs!) either using the
OSMC skin screenshots:
http://paste.osmc.tv/poyoyizivo
One thing: I have two vero4k and the other one has the same problem but play starts and after 2 seconds it stops and returnes to poster wall. On that one displaying actors and playijg trailers dont work
You have enabled debug logging but seem specific component login for SMB is missing.
What are you using as your “server”
I have a synology 1819+
What do you mean by component login is missing?
I followed your instructions.
Are you sure you have chosen “Verbose logging for the SMB library”?
Maybe not, I’ll do it again. Be right back
Hope I got it right this time:
Yes, that had the respective info but still no idea what is wrong.
On your Synology how are the settings for Samba (e.g. protocol version).
I would go to settings>services>SMB client> and enable the “Mitigate MTU issues with SMBv2” option and see if that does the trick.
I updated all add-ons and the skin amber, then I enabled Mitigate MTU- and now it works.(although it takes a few seconds more for the film to start playing)
Thank you all!
Good to hear. If you can enable SMBv3 on your NAS (and possibly set Kodi SMB min/max to v3 in Settings) then you should be able to disable that option again and gain that speed back. Alternatively you could switch over to a system mount which should be even faster.
Sorry for stupid question, but can you please explain what is system mount?
The way you are setup currently Kodi is handling part of the networking tasks involved in streaming files from your network location. A system mount is where you add the network location to the underlying file system so it handles the networking entirely. To do this you would add a system mount via fstab or autofs and then add a path substitution to make Kodi use this with your current library.
