Hey there,
I have playback issues with various videos, which play fine on my computer.
Basically the video playback is about about 0.4x of normal speed (audio playback is normal), then skips forward to be in sync again.
What they have in common:
- newer releases from the Anime scene (eg. Glue, Asenshi)
- they use yuv444, 10bit
A sample mediainfo
General
Unique ID : 197933291920462532061969204692046494353 (0x94E890BD676D70D8906B4A4CDD66BA91)
Complete name : 9.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 412 MiB
Duration : 23 min 40 s
Overall bit rate : 2 437 kb/s
Movie name : Kono Subarashii Sekai ni Shukufuku wo! 2 - 09
Encoded date : UTC 2018-02-28 16:22:20
Writing application : mkvmerge v8.3.0 (‘Over the Horizon’) 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Attachments : ANA-OneiroparmEni82.ttf / Balloon.ttf / BSOD.ttf / Feeding a Moment.otf / Frank the Architect.ttf / Hawaiian Aloha BTN.ttf / NozakiDialogue-Bold.otf / NozakiDialogue-BoldItalic.otf / Pixel Font-7.ttf
Video
Format : AVC
Format profile : High 4:4:4 Predictive@L5.2
Format settings : CABAC / 16 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:4:4
Bit depth : 10 bits
Scan type : Progressive
Title : A Goddess for This Corrupt Hot Springs Town!
Writing library : x264 core 152 r2851+58 429492e t_mod_Custom [10-bit@all X86_64]
Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x1:0x131 / me=tesa / subme=10 / psy=1 / fade_compensate=0.80 / psy_rd=0.70:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=1 / threads=16 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=17.0000 / qcomp=0.74 / qpmin=0:0:0 / qpmax=81:81:81 / qpstep=4 / vbv_maxrate=960000 / vbv_bufsize=960000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=3:0.82 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=1:0.87 / aq2-sensitivity=15.00 / aq2-factor=1.00:1.00:1.00 / aq3=4:[0.19:0.19]:[0.19:0.19]:[0.19:0.19]:[0.19:0.19] / aq3-sensitivity=10.00 / aq3-factor=[1.00:1.00]:[1.00:1.00]:[1.00:1.00] / aq3-boundary=768:256:96
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Title : FLAC 2.0
Writing library : libFLAC 1.3.2 (UTC 2017-01-01)
Language : Japanese
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : Chihiro
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Prologue
00:01:27.504 : en:Opening
00:02:58.053 : en:Part A
00:14:10.058 : en:Part B
00:22:00.069 : en:Ending
00:23:30.074 : en:Preview
If additional info is needed to solve this, I happily supply them.
Kind Regards
