Hi there
I have some files encoded in H264 - MPEG-4 AVC (part 10) (avc1), that play nicely enough on opening, but as soon as I try to search, fast forward, rewind etc., it freezes. Sometimes it then just closes the video, and other times it freezes the system completely until I reboot.
Had the same problem on my RPI3 with OSMC. Thought it was just a hardware issue, but the same problem appears on my brand new Vero 4K (freshly installed).
What gives?
This is the file infomation from Media Info:
General
Complete name : C:\Users\Hetoft\Downloads\test.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp41/mp42/isom)
File size : 2.01 GiB
Duration : 37 min 38 s
Overall bit rate : 7 646 kb/s
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : No
Format settings, RefFrames : 2 frames
Format settings, GOP : M=1, N=24
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 7 528 kb/s
Maximum bit rate : 768 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Original frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.341
Stream size : 1.98 GiB (98%)
Title : Core Media Video
Encoded date : UTC 2017-07-31 18:02:08
Tagged date : UTC 2017-07-31 18:48:12
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Source duration : 37 min 38 s
Bit rate mode : Constant
Bit rate : 112 kb/s
Nominal bit rate : 128 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 30.1 MiB (1%)
Source stream size : 30.1 MiB (1%)
Title : Core Media Audio
Language : English
Menus : 3
Menu
Codec ID : text
Encoded date : UTC 2017-08-24 13:50:23
Tagged date : UTC 2017-08-24 13:50:23
Menu For : 1
00:00:00.000 : Chapter 1
