I’ve a DVD ripped to x264 with DVDFab. Copied video and audio as is and saved subs to file.
When I play the x264 (mkv) file on OSMC (Raspberry pi 2) the video and audio aren’t in sync. Video runs slow and catches up with audio every 10-20 secs. If I play the same files om VLC (on a PC) it plays perfectly.
Does anybody have an idea on how to solve this?
No, but the DVD is converted to x264 MKV file. So there would be no need for MPEG2 licence.
Anyway if you’re convinced that a licence will solve it, I’ll purchase one.
What makes you believe that? If the file would be x264 then yes the codec would not be needed. But the Mediainfo you gave speaks a different language.
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Format settings, picture structure : Frame
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
It may make more sense to just pay the codec license, and save time converting all of your files and avoid a potential reduction in quality from further transcoding.
