In the last couple of months I started having problems playing back certain 4k files, Most work just fine, but some just freeze video, stutter audio or show no video at all and just stuttering audio.
Upgraded to latest release, but no change.
Below is video metadata for one of the problematic files.
Format : Matroska
Format version : Version 4
File size : 5.38 GiB
Duration : 50 min 28 s
Overall bit rate : 15.3 Mb/s
Frame rate : 25.000 FPS
Writing application : mkvmerge v86.0 ('Winter') 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
Video
Format : HEVC
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 14.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.070
Stream size : 5.11 GiB (95%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 277 MiB (5%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
