I’ve been running into problems with certain TV show encodes playing back on my Vero4K+. I thought it might be a KODI level problem as the videos play fine from my Windows machine using MPC or VLC.
However, I also have an AppleTV 4K with MrMC (KODI fork) and it can play the same video with no problems. So I’m starting to think this is OSMC or Vero4K+ specific.
When it plays the audio is fine, but the video drops tons of frames and becomes desynchronized from the audio by a substantial amount. There is also frequent screen freezing while the audio plays just fine. It’s not just a few frames getting dropped it’s massively desynchronized and not flowing at all.
Here’s a mediainfo dump of the file in-case there are any clues?
General
Unique ID : 96285175933275132003584471331647056364 (0x486FD9B0BCC68FD3D552583753E4E9EC)
Complete name : \video\TV\Last.Week.Tonight.With.John.Oliver\Last.Week.Tonight.with.John.Oliver.S06E19.720p.mkv
Format : Matroska
Format version : Version 4
File size : 1 011 MiB
Duration : 31 min 20 s
Overall bit rate : 4 512 kb/s
Writing application : mkvmerge v35.0.0 (‘All The Love In The World’) 64-bit
Writing library : libebml v1.3.9 + libmatroska v1.5.2Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Constant
Bit rate : 4 372 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(PixelFrame) :* 0.079
Stream size : 982 MiB (97%)
Default : Yes
Forced : NoAudio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 125 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 28.1 MiB (3%)
Language : English
Default : Yes
Forced : NoText
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 31 min 11 s
Bit rate : 264 b/s
Count of elements : 1185
Stream size : 60.5 KiB (0%)
Language : English
Default : No
Forced : No
