Playback Video - sound stuttering after March 5th Update
That seems to have done the trick – thumbs up :+1:
Good stuff.
It seems to be solved with the current (October 2018) kernel.
Thank you :blush:
Running a couple days now with no issues. Thank you for all your hard work.
I’ve used the October release since the upgrade, and in most cases it works fine. However, I’ve found a couple of TV recordings (HD) that give constantly crackling sound. I’m using the analogue audio output.
I’ve installed the February release on another (larger, but slower) SD-card, and on that release, there is no crackling in the sound.
In both cases, the video file is played back from an NFS server on the local network. The network has Gigabit switches.
Would a small extract from the video file help in diagnosing this problem?
Does “audio_pwm_mode=0” added to config.txt avoid this issue?
Sorry for the late reply; been busy and lost my extra SDHC micro card…
Bought a new card now and installed the latest release on it (2018-12), and the crackling is still present (working perfectly with the 2018-02 release). I’ve added the suggested audio_pwm_mode=0 setting and rebooted, and the crackling is gone.
This seems to be a working configuration again – thanks!
I’ll stay on this version and will report back if audio-problems appear.
Sorry to jump on the end of this thread. I am a very experienced OSMC user, recently had to install 2 more Rpi’s built the same as all the others. Using the latest release just a few days ago. All media is on a central NAS, MySQL for Libraries and there are 9 clients sharing it. 6 Rpi’s OSMC and 2 Fire TV Sticks running Kodi 1 Linux.
I have sound stuttering on the 2 new Rpi’s. Reading through this thread seemed to point to network issues. Have tried wifi connection, wired connection. Bypass any local switches and wired into the main switch (the one that the NAS is on) into the main switch. Nothing seems to make a difference.
I tried rebuilding the pi’s from scratch. These 2 seem to be noticeably slower than the previous ones. Menu refresh etc. They are Model B 3+ units.
Had previous items in the same network ports that worked fine no sound dropouts. All other clients work fine and are responsive and play media perfectly.
All units update automatically so should all be running latest versions. Is there a particular log file you need to look at. Excerpt below with full debugging enabled and component logging for audio I could not see anything obvious.
12:59:48.511 T:1330123520 DEBUG: GetMovieId (smb://USERNAME:PASSWORD@TWHGNAS/TV/Banshee/Season 2/Banshee.S02E06.SD.TV-Armies of One.mp4), query = select idMovie from movie where idFile=10596
12:59:48.527 T:1330123520 DEBUG: GetEpisodeId (smb://USERNAME:PASSWORD@TWHGNAS/TV/Banshee/Season 2/Banshee.S02E06.SD.TV-Armies of One.mp4), query = select idEpisode from episode where idFile=10596
12:59:48.569 T:1886384896 DEBUG: CAESinkPi:Drain delay:99ms now:0ms
12:59:48.569 T:1886384896 DEBUG: CAESinkPi:Deinitialize
12:59:48.570 T:1886384896 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000000
12:59:48.575 T:1886384896 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.audio_render handle 0x5cb4b4d8
12:59:48.576 T:1886384896 DEBUG: CActiveAESink::OpenSink - trying to open device PI:HDMI
12:59:48.576 T:1886384896 DEBUG: CAESinkPi:Initialize Format:24 Channels:2 Samplerate:48000 framesize:8 bufsize:19200 bytes/s=384000.00 dest=PI:HDMI
12:59:48.576 T:1886384896 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000008
12:59:48.577 T:1886384896 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x5cb4b4d8
12:59:48.578 T:1886384896 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_render) - port(100), nBufferCountMin(1), nBufferCountActual(2), nBufferSize(19200), nBufferAlignmen(16)
12:59:48.579 T:1886384896 DEBUG: CActiveAESink::OpenSink - SinkPi Initialized:
12:59:48.579 T:1886384896 DEBUG: Output Device : HDMI
12:59:48.579 T:1886384896 DEBUG: Sample Rate : 48000
12:59:48.579 T:1886384896 DEBUG: Sample Format : AE_FMT_FLOATP
12:59:48.579 T:1886384896 DEBUG: Channel Count : 2
12:59:48.579 T:1886384896 DEBUG: Channel Layout: FL,FR
12:59:48.579 T:1886384896 DEBUG: Frames : 2400
12:59:48.579 T:1886384896 DEBUG: Frame Size : 8
12:59:48.582 T:1895908096 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
12:59:48.587 T:1355289344 DEBUG: Previous line repeats 1 times.
12:59:48.587 T:1355289344 DEBUG: CVideoPlayer::HandleMessages - player started 1
12:59:48.587 T:1355289344 DEBUG: CVideoPlayer::SetCaching - caching state 3
12:59:48.587 T:1355289344 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
12:59:48.587 T:1355289344 DEBUG: CVideoPlayer::SetCaching - caching state 0
12:59:48.588 T:1355289344 DEBUG: VideoPlayer::Sync - Audio - pts: 554090666.000000, cache: 261333.353067, totalcache: 500000.000000
12:59:48.588 T:1355289344 DEBUG: VideoPlayer::Sync - Video - pts: 553970083.000000, cache: 50000.000000, totalcache: 100000.000000
12:59:48.588 T:1403073280 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_RESYNC(553829332.646933)
12:59:48.588 T:1403073280 DEBUG: CDVDAudio::Resume - resume audio stream
12:59:48.588 T:1895908096 DEBUG: ActiveAE - start sync of audio stream
12:59:48.732 T:1895908096 DEBUG: ActiveAE::SyncStream - average error of -45.288418, start adjusting
12:59:48.732 T:1895908096 DEBUG: ActiveAE::SyncStream - average error -0.288418 below threshold of 30.000000
12:59:48.976 T:1411461888 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(553829332.646933)
12:59:49.738 T:1403073280 DEBUG: CDVDClock::ErrorAdjust - CVideoPlayerAudio::OutputPacket - error:-30246.947806, adjusted:-30246.947806
12:59:53.592 T:1411461888 DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
12:59:57.026 T:1925638656 INFO: CheckIdle - Closing session to http://thetvdb.com (easy=0x6fd0c038, multi=0x5cb4f6c8)
While stuttering no error or other anomaly detected in the log.
Any help appreciated.
Current config.txt modified after reading through other posts maxing out the Freqs.
arm_freq_min=1200
core_freq_min=400
gpu_freq_min=400
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
force_turbo=1
Spart
well, it definitely solves the issue (rpi/3, Dec.18 update) by bringing another: very loud hissing. Any ideas?..
