Same problem here, only happends when rtorrent is downloading a file (no matter the download speed). Not happening before March 2018 update.
@sam_nazarko my audio issues have disappeared with a combination of the following.
- Installed your latest build
- changed the speaker setup to 2.0 from 5.1 on the setup - system - audio output - number of channels
Just thought I’d let you know.
mmmmmm…
Memorysize 0
Buffermode 157etc etc
I thinks there’s some errors… try to use the tag CODE
example
Aah, I was wondering how to enter code! Thanks.
But yes, after removing the cache settings in the advancedsettings, my sound issues went away.
My current cache settings are:
buffermode 1
memorysize 123000111
readfactor 30
There’s no reason for this having sound issues. Further more, it was working before.
Maybe but I suggest you try removing your cache settings and see if the issue goes away. It worked for me.
nope. I’ve just made the test:
- removed cache settings.
- restarted kodi.
- started watching a movie
- made transmission tart a download.
once there are enough peers to start downloading, the sound stuttering starts.
again: this DID NOT happened in previous versions.
[EDIT] after pausing transmission downloads and restarting kodi, solves the issue (up to the next transmission download )
I have the same problem, sound stuttering, and downgrade kernel, like Sam propose, work for me.
Other idea. In other sd i am a fresh install of osmc with the same sound problem. I view the solution proposal for cr4wler and I did it.
I add “dtparam=audio=on” in configg.txt, reboot and select “alsa” in system->adjust system->sound->audio output device.
This solve my problem.
I’m seeing the same issue with kodi-bin_17.1+dfsg1-3_armhf.deb on kernel 4.14.26-2-osmc on my raspberry pi B playing mpeg-2 over SMB. audio drops out for ~ 0.25 seconds every minute or so, then the pitch varies for a few seconds as it attempts to re-sync.
Are you sure you’re running OSMC? That sounds like a Raspbian based package to me
I confirm that using sam’s suggestion to force kernel version 4.9.29-10 solves the issue.
(I’ve also added “dtparam=audio=on” to config.txt).
I’m now watching a movie and transmission is downloading some files. all working just fine. No audio stuttering
yeah, pretty sure. my sources.list looks like this:
deb http://mirrordirector.raspbian.org/raspbian stretch main contrib non-free
deb http://apt.osmc.tv stretch main
We’ve never produced: kodi-bin_17.1+dfsg1-3_armhf.deb
Doesn’t come from OSMC.
so, where is the OSMC kodi .deb, then? i don’t see it on apt.osmc.tv.
i’m pretty sure i haven’t changed anything since installing. all i have done is update.
kodi-bin suggests you’ve run something like sudo apt-get install kodi. This is not an OSMC version of Kodi.
dpkg -l | grep mediacenter should show the proper OSMC package if you’re actually running OSMC.
Can people try staging to see if there are improvements?
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
I also recommend you edit /etc/apt/sources.list
again and remove the line that you added after updating. This will return you to the normal update channel.
osmc@osmc:~$ dpkg -l | grep mediacenter
ii mediacenter-addon-osmc 3.0.657 all OSMC addon for mediacenter
ii mediacenter-eventclients-common-osmc 1.0.2 all Eventclient common resources for mediacenter
ii mediacenter-send-osmc 1.0.0-4 all Eventclient send for mediacenter
ii mediacenter-skin-osmc 17.0.4-2 all OSMC skin for mediacenter
ii rbp1-mediacenter-osmc 17.6.0-24 armhf Media Center package for OSMC
Not sure where you got kodi-bin_17.1+dfsg1-3_armhf.deb from then. If you have dpkg -l | grep kodi (kodi packages) on your system, you have contaminated your installation.
this returns nothing.
my apologies, i got the kodi-bin version from apt-cache show
since i figured that’s what would have been installed.
