I got a bluray disc that simply had its folder structure (+ files) ripped. I would like to play this from the main folder, just like playing from a bluray drive.
This worked with Kodi on a (linux) PC. But not on the Vero 4K. Looking at the log, I get the error:
The kodi version on my PC is 17.6, built Nov 18,2017 (for linux x86_64). I just updated the Vero 4K, and also installed libbluray1. The kodi version (on the Vero4K) is the same: 17.6, compiled on Mar 12,2018.
Will this just not play on the Vero 4K (at this moment)?
TIA
ken
I can upload the full log, if needed. But, IMHO, the above message makes clear what the error is.
UHD disc? Newer libbluray is needed, rudimentary UHD support (without BD-J support) was added with version 1.0.2. OSMC comes with an older version right now… Don’t know if you just can upgrade the lib or if a Kodi recompile is needed / works. Sam?
I remember seeing such a message some time ago. I wasn’t able to test if a new version would be beneficial and IIRC the Nevcairie patch series wouldn’t apply.
I’ve built libbluray 1.0.1 now and you can try this. To test this update:
Add the following line: deb http://apt.osmc.tv stretch-devel main
I will only point out that - as I said initially - the linux PC version of Kodi did handle this. It’s not a big deal for me, since I only have one bluray video folder. Everything else has been ripped to mkv.
Now that v18 is out, can full bluray support be expected? Tried some, but issues seem to be present. Should Java or something else be installed / enabled somehow?
Only thing remaining for the device to be perfect. REMUX is not ok for concert blurays…
