I have ripped all my Bluray disks to ISO files on an external disk and I would like to play then through KODI on OSMC on a Pi3
I have seen several posts on problems people have been having getting this working but I have not seen a final way of achieving playback.
Is playback possible and if so what do I need to do to make it happen
Thank you all for your help
Keith
Yes – you should be able to playback the ISOs, but menu support will not work if they use BD-J.
Hi @sam_nazarko
Thank you very much for replying. Whenever I try and play any of the Blu-ray disks I get a pop up saying it is encrypted.
Do I need to get the codecs for the pi. I thought I read something that said they weren’t needed anymore
Keith
You can install the AACS keys or rip the disks so they are not encrypted.
Hi @Sam I have been looking for instructions on how to set this all up but I can’t find a definitive script. Do you have any instructions for this?
Thank you very much for your time
