Playing dvd`s on alpha 3?
hello there,
i’ ve download the alpha 3 version for raspberry pi. The dvd structure wil not work. what dit i wrong?
thanx
Ed
Can you provide a log or explain how you tried to play the DVD?
Also – do you have the MPEG2 codec license installed?
hi Sam,
the mpeg2 codec is installed.
the dvd video ts file is on a server. In the latest version of rapsbmc it works fine. i select the video_ts.ifo file and the dvd starts. In alpha 3 i select the file and it looks like it wil start up but then notting happens and it returns to the video_ts folder.
Can you get us a log to show this?
Hi Sam,
the file is online. You can download it here www.vanpeltmontage.nl/osmc/logfile.txt
I see
19:13:50 T:2852197408   ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
19:13:50 T:2852197408   ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
19:13:50 T:2852197408   ERROR: Open - failed to open source <http://192.168.1.108:50002/v/NDLNA/7932.VOB>
19:13:50 T:2852197408   ERROR: CDVDPlayer::OpenInputStream - error opening [http://192.168.1.108:50002/v/NDLNA/7932.VOB]
19:13:50 T:2852197408  NOTICE: CDVDPlayer::OnExit()
19:13:50 T:3024371712   ERROR: Playlist Player: skipping unplayable item: 0, path [upnp://00113208-20cb-0011-cb20-cb2008321100/44%24%407932/]
19:13:50 T:3024371712  NOTICE: CDVDPlayer::CloseFile()
I keep seeing timeouts in your log. Are you using a WiFi connection?
no, pi is wired to the server
i`ve just uploaded a new logfile from 22.00 hour.
www.vanpeltmontage.nl/osmc/kodi.log
Please try to play the DVD from something else than UPnP.
I have a feeling that UPnP and DVD structure can be problematic, but please rule it out first. I have seen such reports on the Kodi forum, but on other platforms.
If this is indeed the issue you should report it at the Kodi forum.
Thanx for the tip.
made an smb link and everything works just fine. i think there`s a bug in kodi for UPnp.
