So, really odd one…
MP3 files stores on PC - PC plays those files fine (VLC)
Those same files across network to RPi3B running OSMC - Plays files fine
Those same files across network to Vero 4K - Vero whizzes through the folder, each filename appears for a fraction of a second in the top-right. Start to finish time about 3 seconds.
It doesn’t do it for all files (this came to light playing the Now! collection 1-75 is fine, 76-104 isn’t)
Vero is up to date with all updates etc.
Anyone got any ideas please?
Yes the first idea I have you should provide debug enabled logs.
reproduce the issue
When you scrape your music into a library it stores the file path in a database along with the information about the media. When you tell it to play something it adds all the files to a playlist. When a file in a playlist is not found then it skips that file and goes to the next. If all files in a playlist are not found then you see what you describe. If you had renamed some file/folders to cause this behavior then you would need to clean your audio library and then update it again to pick up the new file paths.
The original copying of the files was straight in to the correct location, no re-naming, no re-location, no anything, just a straight copy from the source USB Stick onto the PC. They were already in a completely logical structure in the first place
Anyway, selecting the file directly does not work.
Cleaning the library, does not work. (the system has exactly zero playlists too, as I go to the files direct.)
Creating a new folder and copying the files in there, doesn’t work on the Vero, does work on the Pi and PC.
When I’m next there and not doing it remotely via the girlfriend, I’ll switch on the logging and see what occurs.
