i use DisneyPlus and OneDrive Addon to stream videos.
Everything worked fine until yesterday: During an ongoing stream on disney the video interrupted and could not be continued. Now when i want to start a stream on disney OR onedrive, the stream starts for 1 or 2 seconds and then the screen is freezing (no audio also). I can go back to the menu but the behaviour is always the same when i want to start a new video.
With activated debugging i can see this error when it comes to the screen freeze:
error : CDVDVideoCodecDRMPRIME::AddData - send packet failed: End of file
Here the full log file when starting a video from onedrive:
Appreciate any support…
Update:
As requested here the full logfile from osmc logfile uploader:
reproduce the issue
Thanks, i updated my initial post with the requested log file
Are you able to try with a different power supply?
Regards Tom.
Hi Tom,
thanks for that hint. Unfortunately ist doesnt work either. I tried it with two other Power supplies.
Regards
Marco
Logs suggest if it isn’t a bad psu, it could be a failing sd card. I would back up your settings and install on a fresh sd card and restore your settings.
Regards Tom.
Thanks Tom. That helped. It is running now.
