Please add firmware for DVB-T AverMedia AVerTV Volar Black HD (A850)
Hello,
would it be possible to add the firmware for DVB-T A850 in next OSMC release ?
I’ve downloaded/copied it manually to “/lib/firmware/” and it works great.
Here is the log:
osmc@osmc:~$ dmesg | grep dvb
[ 4.249065] usb 1-1.4: dvb_usb_v2: found a ‘AverMedia AVerTV Volar Black HD (A850)’ in cold state
[ 4.335781] usb 1-1.4: dvb_usb_v2: downloading firmware from file ‘dvb-usb-af9015.fw’
[ 4.420368] usb 1-1.4: dvb_usb_v2: found a ‘AverMedia AVerTV Volar Black HD (A850)’ in warm state
[ 4.803460] usb 1-1.4: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 4.837022] usb 1-1.4: dvb_usb_v2: ‘AverMedia AVerTV Volar Black HD (A850)’ successfully initialized and connected
[ 4.837174] usbcore: registered new interface driver dvb_usb_af9015
Again thank you for your excellent work!
@sam_nazarko
The firmware file is located at :
http://www.otit.fi/~crope/v4l-dvb/af9015/af9015_firmware_cutter/firmware_files/4.95.0/dvb-usb-af9015.fw
I’ve been using it for two months without problems
Thank you to the whole OSMC team for the excellent work!
