pg 42/43 refers to setting HDMI control
BTW I think most/all TV TOSlinks will only output PCM stereo. There is no way they can automatically find the capabilities of the device at the other end of the cable, so unless thereâs a setting for enabling DTS/DD you are indeed stuck with stereo for that connection.
Thank you all for your generous attempts to help. Iâm very frustrated. This is not a Vero issue though but rather something that is not working as I expect between the LG E9 TV and the Yamaha YSP-2200 soundbar.
To maximally simplify I have reset the AV settings of the TV, disconnected all but the Yamaha, which I cabled to the TV both attempting TV-HDMI2(ARC) port to Yam-ARC(OUT) cabling and also TV-HDMI2(ARC) port to Yam-HDMI-Input1 port. Set the TV audio to go our to ARC which also enables wmothing called Simplink. Turn on the TV but no sound at all on the soundbar.
So I guess Iâm stuck to Vero to LGTV to get 4K video and TOSLink to Yamaha getting 2ch stereo
Not happy.
I havenât read the whole thread but why only 2ch Stereo via the TOS link? I have a similar setup with a Panasonic TV and get 5.1 via TOS to my Amp.
Hi @fzinken nice to read you. Hope youâre doing great.
Too ignorant to speak about standards
but empirical tests playing multichannel movies on the 4K+ and the âmultichannelâ LED on the yamaha not coming on as it does when Vero is connected to the soundbar via the HDMI cable.
Well it is a question how the LG passthrough the audio. Maybe it acts differently when using different HDMI ports.
Maybe upload logs from when it is connected directly to the LG so that we can see the advertised audio modes from the LG (or point me to a previous log upload).
So right now I have settled for Vero connected to LG via HDMI and the sound to the soundbar via the TOSLink from the LG to the soundbar.
Would this be ok for your to better understand?
Standard procedure of activating logs and uploading them? (must remember or find the link to instructions)
Thanks a lot
If you have SSH access then just use grab-logs -A
reproduce the issue
upload the log set (all configs and logs!) either using the
Thank YOU ALL so much. Will do whatever it takes.
So before I go on BIG NEWS
I fumbled with the YSP-2200 setup menus and now things are a LOT better even though still need some help.
Right now the 4K+ is connected to LG E9 on its HDMI1 port, TOSLink disconnected, LG E9 Audio routed to HDMI ARC (and keeping the remote pressed on it for more that 3 seconds a submenu appears and selected PASSTHRHOUGH and eARC OFF), cable from LG E9 eARC-HDMI2 port to Yamaha ARC(OUT) port and the audio finally works !!!
What I need to iron out now are:
a) the LG remote does not work for OSMC
b) The TV shows thereâs a Vero4K+ device on HDMI1 but also a KODI device on HDMI2. When Iâm on the Vero/Kodi/HDMI1 screen and eith Veroâs remote I press play, the TV switches to HDMI2-Kodi and displays âno signalâ for Video.
Will upload the logs shortly to see if you can make sense of this.
Power of the Vero and the TV at the main power for a couple of minutes.
But generally CEC on LG is bad. You also can try to press symlink button and activate Vero HDMI again
So here are the logs: https://paste.osmc.tv/ojoxuzeqif FWIW the âupload logsâ through the MyOSMC menus just exited without giving me the pastebin URL but the ssh method worked flawlessly.
As sometimes things go in these complicated environments, through the logging runs no problems at ll showed up and all worked as it should SAVE for being able to use the TVs remote for Vero/OSMC.
So the TV seems to report all supported audio respectively
====================== Audio Cap =================== k3dRrf31 CodingType MaxChannels SamplingFreq SampleSize PCM, 8 ch, 32/44.1/48/96/192 kHz, 16/20/24 bit AC-3, 6 ch, 32/44.1/48 kHz, bit Dobly_Digital+, 8 ch, 32/44.1/48 kHz, 16 bit MAT, 8 ch, 48 kHz, 16/20 bit DTS, 6 ch, 44.1/48/88.2/96 kHz, bit DTS-HD, 8 ch, 44.1/48/88.2/96/176.4/192 kHz, 16 bit ---------------------- Audio Cap END --------------- k3dRrf31
Maybe one of the Audio Guruâs can review your settings but I think you can change the Channels back to 2.
====================== GUI Settings (abridged) =================== z9Z12KgS Dolby Digital (AC3) capable receiver: true Enable Dolby Digital (AC3) transcoding: false Audio output device: ALSA:default Number of channels: 7.1 ===> Default: 2.0 Output configuration: Best match DTS-HD capable receiver: true DTS capable receiver: true Dolby Digital Plus (E-AC3) capable receiver: true Play GUI sounds: Only when playback stopped Allow passthrough: true TrueHD capable receiver: false Adjust display refresh rate: Off Sync playback to display: false Disable stereoscopic 3D mode when playback ended: true Playback mode of stereoscopic 3D videos: Ask me Display 4:3 videos as: Normal Enable HQ scalers for scaling above: 20 Allow hardware acceleration - amcodec: true Accelerate MPEG2: Always Accelerate MPEG4: HD and up Accelerate h264: Always Force 422 colour subsampling: true Force RGB output: false Use limited colour range (16-235): false Lock HDMI HPD: false GUI Resolution: 1920x1080 @ 60p ---------------------- GUI Settings (abridged) END --------------- z9Z12KgS
@fzinken thanks a lot. You mean going back to 2.0 in OSMCâs audio settings?
Yeah as that is not related to the Passthrough part anyhow.
But maybe wait till one of the others have read and commented
Now the Yamaha soundbarâs volume works through the TVâs remote
This is good news.
Only step to heaven is OSMCâs menus through the same remote
Did you do the full power down step?
Did you try symlink button?
Have you checked CEC enabled on Vero?
- Yes
- not understandinf what you mean by that
- I have CEC Adapter 4.0.4-firmwarev5 enabled; Not sure if/how I should change some of its other options (as far as I can understand the only other enabled option is âSwitch source to this device on startupâ)
You should have a button on the LG remote called SymLink, or? For me when I press that button I get a menu to choose the HDMI SymLink (LG name for CEC) device.
Thereâs a button up top near the Power button and when I press it it prompts âYou can use your Magic Remote to contro yoyr se-top box. Do you want to continue?â ⌠Yes of course
This open up a âSelect device you want to connectâ and gives 4 choices: âSet-top box/ottâ , BluRay, Home Theater and soundbar.
The âset top boxâ shows its connected to HDMI1 (true), then an icon of the remote with a checkmark, then it says Input HDMI1, Device Typr Set-Top Box/OTT, Service: Flirc and Set for Universal Remote: Complete. Then I have a Set Manually and a Reset Device choice
What about Home Theater? But overall this sounds different to what I have.
