I hope someone can help me. I just bought a raspberry pi 2 for my parents OSMC setup at their house. I had the RPi 1 before and the edimax wifi was too far away from the router. So I bought the ac-51 hoping it would perform a bit better.
I have been reading up on finding drivers for this but still a bit noob with the osmc distro and the systemctl operations etc etc etc…Anywho. I found the lsusb with the driver.
Just hoping someone can show me how to install it. I found a page on ubuntu that had me download the 8812au drivers and placed them in /home/osmc and tried to make. but I am missing headers?
Can someone help? Thanks!!!
root@Kodi-Maris-LR:/home/osmc/rtl8812AU_8821AU_linux-master# make
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/4.3.0-10-osmc/build M=/home/osmc/rtl8812AU_8821AU_linux-master modules
make[1]: *** /lib/modules/4.3.0-10-osmc/build: No such file or directory. Stop.
Makefile:1049: recipe for target ‘modules’ failed
make: *** [modules] Error 2
Bus 001 Device 004: ID 0b05:17d1 ASUSTek Computer, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.01
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0b05 ASUSTek Computer, Inc.
idProduct 0x17d1
bcdDevice 1.00
iManufacturer 1 MediaTek
iProduct 2 WiFi
It looked like it accepted? the command without the build at the end, well it didnt say anything actually so I am unsure.
What is the next step for getting the driver installed, it looks like my instructions are for ubuntu and none of the commands are working. I am just trying to get this USB-AC51 installed but I only see eth0 and lo under ifconfig please help. thanks!!!
You shouldn’t need to build this driver. It’s included in OSMC at the moment. You are likely using a new device which hasn’t been referenced in the driver yet. dmesg and lsusb will help us get this added.
Ya I read somewhere that it was installed already which makes me even more confused.
Ok here is what I got for dmesg:
and for lsusb:
osmc@Kodi-Maris-LR:~$ lsusb
Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Thank you so much for your help it is much appreciated. Again I am noob with this driver ordeal so if you can walk me through that would be awesome
Thanks!
Any luck with the driver on this one? Not to rush or bug I am just hoping to get this done by today tomorrow since I am leaving to family where this will be going on Tuesday.
