Hello,
I just tried to upgrade my vero4k+ with the march update, it is now stuck on “Please stand by” screen (black background, light blue font).
I tried to reboot it, the same screen appears and stays.
I tried to reinstall OSMC, even with recovery procedure (toothpick switch, with USB key and micro sd card…), nothing happens, the “Please stand by” is very still…
Thanks for any ideas that could help !
Best regards
plug an USB keyboard to see if it reacts : not at all. (I can’t even switch the numlock (there is a led to see), which is usually possible an a early boot stage…)
Tried it several time, with different USB keys, on both USB ports, nothing new…
(I here the click of the button pressed with the toothpick before plugging the power)
And I might be able to communicate with the device in rescue mode through USB interface ?
(with a special software ?)
Might worth a try, especially under the COVID isolation, if it’s not to much work for you to guide me in this process.
I will try to build such a cable tomorrow, folowing https://www.instructables.com/id/Male-to-Male-A-to-A-USB-Cable/
[ 4125.001243] usb 1-4: new high-speed USB device number 4 using xhci_hcd
[ 4125.023513] usb 1-4: New USB device found, idVendor=1b8e, idProduct=c003, bcdDevice= 0.07
[ 4125.023516] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4125.921701] usb 1-4: USB disconnect, device number 4
[ 4128.097764] usb 1-4: new high-speed USB device number 5 using xhci_hcd
[ 4128.120200] usb 1-4: New USB device found, idVendor=1b8e, idProduct=c003, bcdDevice= 0.07
[ 4128.120206] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
