I’ve applied the update. I’ll confirm that it is working when I get off work later. I don’t have a 4K screen here to test with.
Thanks!
Thanks!
Great – let me know! If it’s good, I’ll push this as a regular update.
Confirmed. No issued on the 4K set after the update.
By the way, tvheadend did install, no issues there either.
I’m looking forward to getting everything dialed in. I’ve been with you since the Raspbmc days. Thanks.
Thank you for taking the time to confirm this as resolved. I’m now confident to push this as an update to other users.
Thanks for your kind words too – I hope you enjoy the device!
Make sure you reverted your sources.list as instructed above or you may receive some updates a little bit earlier than we can consider them stable.
Cheers,
This topic was automatically closed after 2 days. New replies are no longer allowed.
