Please support with VOLUME
Dear friends,
I use OSMC with love and there is something VERY strange even after installing the OSMC many times.
When I see a video or hear music, if I try to use my keyboard to turn the volume down - Nothing happens and I cannot see anything on the screen.
When I press the volume up, I see on the screen the volume bar full.
I changed all the settings (pass trough) and other but without any success.
Just for the information - I am NOT using pass trough.
Thank you!
Ilan.
The default key mappings for master volume are + and -. (Mute is F8)
Are you saying this is not working on a fresh install ? (works for me…)
Didn’t work for me either when using my wireless keyboard, no volume down or mute, I had to load a custom keyboard.xml file
Thank you Mandrake and pscriven.
I didn’t worked for me on my keyboard with media controls.
I tried many Kodi installations.
pscriven - Can you tell me how you installed the custom keyboard.xml?
Thank you.
Try the file from Dilligaf in this thread, instructions included:
https://discourse.osmc.tv/t/volume-down-mute-key-failure-sovled/
Thank you very much.
Now my unit is dead so I cannot try it…
